Corrosion on heat lines at boiler
pcgodaire
Member Posts: 1
Four years ago we installed/modified piping at a boiler to add radiant zones. I got a call from the owner that they were seeing some corrosion on some of the piping. We used black steel pipe and added some brass ball valves. The corrosion is only happening on the boiler side of the valves. Any idea why this is happening. See pictures attached.
What's the water chemistry like? Is there an auto-feeder in use?0
I agree with Bob, it looks like a thread leak. If the bottom of the valve was done like the top it looks like not enough thread sealant was used.0
Packing nut behind handle
Wire brush and spray paint0 -
I don't see any evidence of thread sealant, of any kind.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
