Rinnai tanklesss comversion....
kcopp
kcopp Member Posts: 4,576
Have any of you folks converted a Rinnai tankless water heater from one gas to the other? I have a customer who has an LP one and now they are running the NAT gas line past the house.
generally speaking WH mfg frown upon this....
ty,kcopp
  • 4Johnpipe
    4Johnpipe Member Posts: 487
    Call Rinnai. They have conversion kits. I believe you have to change the gas valve.
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • 4Johnpipe
    See this...
    732-751-1560
  • lchmb
    lchmb Member Posts: 2,997
    Done it from natural gas to LP. Followed the directions and purred like a kitten..
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    I have LP to natural. You have to change the burner plate its not bad to do.
  • kcopp
    Thanks.
  • rick in Alaska
    rick in Alaska Member Posts: 1,491
    Done a lot lately. You do have to give them the model and serial number to get the correct plate, but once you get it it is pretty easy to do. I would recommend an impact driver to break the screws loose though. Some of them strip easy without it. Also, you will need a manometer to set the pressures after you are done.
    Rick
