Causes of restriction to flow in radiant pex heating system.
chingo
Member Posts: 22
Many things can cause restriction to flow. 1. Air in system 2. Cavitation 3. Kink in a pipe 4. Bad check valve 5. Bad pump 6. Bad flow meter 7. Bad isolation vavles 8. Bad mixing valve 9. Too long a run for diameter of pipe Have i missed anything??????
Please tell me someone is going to put chairs under that mesh before the pour...0
lifted during pour0
Will you be doing the lifting yourself? "The concrete guys will take care of it" has a rather poor track record in this industry.0
yeah your probably right that's why i was there on the pour0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
