Causes of restriction to flow in radiant pex heating system.
chingo
chingo Member Posts: 22
Many things can cause restriction to flow. 1. Air in system 2. Cavitation 3. Kink in a pipe 4. Bad check valve 5. Bad pump 6. Bad flow meter 7. Bad isolation vavles 8. Bad mixing valve 9. Too long a run for diameter of pipe Have i missed anything??????
  • SWEI
    SWEI Member Posts: 7,342
    Please tell me someone is going to put chairs under that mesh before the pour...
  • Zman
    Zman Member Posts: 7,609
    Kurt,
    It is good to dream...
    Carl
    Albert Einstein
  • SWEI
    I always figure that if you're going to dream, you might as well dream big...
    RobG
  • chingo
    lifted during pour
  • SWEI
    Will you be doing the lifting yourself? "The concrete guys will take care of it" has a rather poor track record in this industry.
  • chingo
    yeah your probably right that's why i was there on the pour
