Threading in place?
JohnNY
Member Posts: 3,326
As you can see, I'm connecting new valves to previously bent and welded pipe. My guys are using a mix of the Ridgid 700 and threading by hand. Am I missing something? Is there a better tool for this? The 700 scares me. It's heavy and awkward.
Thanks!
Thanks!
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
I've used the Rigid 600 to do 1 1/4" in place. It comes with the pipe clamp/vise to hold the tool as it threads. The pipe clamp is necessary even on 1/2" IMO as the tool has a lot of plastic in the handle (really good plastic, but still plastic). The 1 1/4" really tests the durability of the clamp....you want it very tight with the teeth clean.1
Going for a ride..lol. 25 years ago, when employed by an oil co. my helper was up on a extension ladder drilling a 3 1/2" hole thru the side of a house with a right angle, for a minisplit. The drill had a tendency to lock "on". Well, Lee caught a knot or a nail that threw him off the ladder, he landed on the grass below. We watched the drill continue to spin, taking out a nearby picture window with the protruding handle, until it wrapped up the cord enough to pull it out of the extension cord. The homeowner was watching open mouthed from said picture window.0
Mega-Press?0
I would use Mega Press if you can. Don't know if it's allowed in the big city or not though.
Ive used a 700 with a 1 inch chuck adapter to drive a 2 1/2 to 4 inch adjustable die in place both vertically and hortizontally and i am not a giant nor of super human strenth .Just make sure your piping can handle the weight more then a few times i ve had to build temporary bracing to sure up the piping .Usually in place w the 700 about 15 to 20 minutes with getting the die on and off but sometimes a few hours for the set up .Its not impossible task and in the proper hands not a biggie i ve done it more then i care to think about and only a few times where we forced to do it by hand which was harder and much more un safe in my eyes espically on a vertical hanging pipe with a bit of height nothing to get leverage against .Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
Nice view,never had a problem threading by hand largest we did was 2in.I guess megapress is an easier solution if you have the equipment.I always like to go back to riser is the tee on riser brazed?Sorry didnt read the welded part.Always risky with city work you gotta worry about that riser god forbid something broke.I think Viega are getting mega press passed in the city for certain applications not on gas though.0
The Rems Amigo is a great tool for that. It has a bracket that bolts onto the pipe and holds everything in place.0
That Amigo thing looks pretty cool.
Classes0 -
At least you have a great view while doing it!--NBC0
Hahahahaha, @jonny88,
It's 1" and I do my fair share when the chips are down. Believe me. I still carry a comprehensive bag of hand tools. Not because I want to. Some days it's either I do it or it ain't happenin'.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
Yup can't agree more about payment crap....when your doing the job ,its there money,when your done its your money... The power of the permit, no pay,no inspection no turn on....get your money in the glory...How many times have you herd, gee the guys at work said that was a lot of money,they got it done much cheaper..Your hard work that you were proud of just went down the crapper....It only takes one (ahole) to ruin your day... That type of people burned me out....jonny88 said:Yep but honestly a company your size in NY sometimes the best tool is your phone cause when that stops ringing your in trouble.Work is the easy part.Getting it and getting paid not so....In my experience anyway.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
