Grundfos
onedriven
Member Posts: 7
Hi
Just wondering if anyone can give me some info on a circulator pump. I have a Grundfos UP 15-42 B7 circulator. Would it be okay to use it on a 5 loop system with approximately 1000 ft of pex pipe total? The system is for secondary heat only.
Thanks
Thanks
That should work just fine provided the boiler and other piping have average resistance."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
