Yet another poor install
njtommy
Member Posts: 1,101
There's a real gem huh ?
Maybe some of these poor consumers could start a class action against the utilities who actually give rebates for this install . Yes , Virginia , they do pay rebates and incentives for this garbage . As a matter of fact 70% of the so called century club (100 jobs per annum) installs look only a bit better than this . But hey , the high efficiency unit is installed right ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Yes it's very high efficient when the boiler is firing up to 180f on a 50f day.
First floor zone is a mix of rads and cast iron baseboard.
Second floor and third floor are cast iron baseboard as well.0 -
Thats some unique gas piping. I guess its at least not CSST.0
Complaint was first floor no heat. Aka bottom circulator. The wiring connection was broken in the wire nut.
Turned unit back on up stairs zone was running and getting nice and hot. Down stairs pump was running but Not heating up once you turn the upstairs off the down stairs zone heats up no problems.
They said this has been a problem since they bought the house a few years ago.0 -
I'm sure he did0
Missed that in the intertwined mess.0
That's not heavy enough wire to bond.0
