Yet another poor install
njtommy
njtommy Member Posts: 1,101
edited October 2015 in THE MAIN WALL
Yet again a poor install on a Navien combi boiler.
  • Rich_49
    Rich_49 Member Posts: 2,783
    There's a real gem huh ?
    Maybe some of these poor consumers could start a class action against the utilities who actually give rebates for this install . Yes , Virginia , they do pay rebates and incentives for this garbage . As a matter of fact 70% of the so called century club (100 jobs per annum) installs look only a bit better than this . But hey , the high efficiency unit is installed right ?
    732-751-1560
    Rich McGrath 732-581-3833
  • njtommy
    Yes it's very high efficient when the boiler is firing up to 180f on a 50f day.
    First floor zone is a mix of rads and cast iron baseboard.
    Second floor and third floor are cast iron baseboard as well.
  • RobG
    RobG Member Posts: 1,843
    edited October 2015
    That's what you get when you drop the helper off in the morning with a box of parts and a torch, go to the bar until four o'clock and then pick him up and collect the customers money.
    You really cant even critique it because you can't tell what the hell is going on.
    What was the complaint?
    Gordy
  • Gordy
    Gordy Member Posts: 9,546
    Thats some unique gas piping. I guess its at least not CSST.
  • njtommy
    Complaint was first floor no heat. Aka bottom circulator. The wiring connection was broken in the wire nut.
    Turned unit back on up stairs zone was running and getting nice and hot. Down stairs pump was running but Not heating up once you turn the upstairs off the down stairs zone heats up no problems.
    They said this has been a problem since they bought the house a few years ago.
  • RobG
    I wonder if their home inspector gave it his blessing, it wouldn't surprise me.
    Gordy
  • njtommy
    I'm sure he did
  • kcopp
    kcopp Member Posts: 4,715
    Ahhh. But it is csst. Not even bonded the right way. Note the floor flange on the floor, the tee and where it goes back to another appliance.
  • njtommy
    Here it is.
  • njtommy
    I will say the cast iron baseboard and rads where really nicely painted and in great shape.
    RobG
  • Gordy
    Missed that in the intertwined mess.
  • Bob Bona_4
    That's not heavy enough wire to bond.
