Another Vito Combi
Paul Pollets
Member Posts: 3,656
Just commissioned this Viessmann 222F combi with a "staple-up" main floor and wall panel radiators on the 2nd fl. Took out an oil-fired steam system that was way past its prime. The owners took advantage of the new gas main on the street and we piped the home for new gas appliances. This boiler is a compact answer to smaller homes with less than 3 baths. The integral HX and SS storage tank won't handle filling a large soaking tub or huge DHW flow rates, but has many advantages.
4
Paul, really nice and clean work. I like that expansion tank bracket.0
Wow looks great.0
WOW
nice and clean i do have to ask about the expansion tank support bracket. who makes its?0 -
you have to love fostapex for a clean pex install.
I have to ask, why the odd fill/backflow combination? Code specific?0 -
The RPZ is required in WA state. The fill valve (PRV) is attached to the RPZ0
Right, thought so. We use the combination units up here, watts 911s, or caleffi 573009A0
Does that unit have a internal expansion tank for the heating side?Aaron Hamilton Heating
ahheating@ yahoo.com
(207)229-77170 -
Yes, it has an internal exp. tank within the cabinet for heating side.0
Nice install and nice to see you using their mixing valve as a complete package.:NYplumber:0
we always use the mixing valve and motor when establishing a required secondary temperature.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
