Replacement igniter assembly for 1979 boiler
eroltan
eroltan Member Posts: 1
Our boiler is a work horse and has been well taken care of. But the igniter assembly has gone and the manufacturer says they no longer make the parts for the 1979 gas boiler model. Do we have any other options to find a part or have it made? Please help!
  • BobC
    BobC Member Posts: 5,556
    Make and model? Also a picture would help.
    Bob
    3PSI gauge
    RobG
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Is this a silicon carbide igniter? If so are there any numbers on the igniter? Igniters are still available for every unit that is out in the field so it can be replaced it is just a matter of getting correct numbers.
  • wcs5050
    wcs5050 Member Posts: 174
    I think you called me on friday. Rec'd by the murphys? Hope you got someone to figure it out.
