Boiler warm up
Flip
Member Posts: 40
Does any one know of a control to slowly warm up a residential CI steam boiler.
What would be the purpose of such a thing?--NBC0
I'm interested as well, what are you thinking the benefit will be?
Easier on the block?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
NBC, would like to use it in the early or late part of the season when the boiler is cooling down in the afternoon when it is off and then starting in the night cold.
Chris J, exactly0 -
Setting you thermostat to 3 cycles per hour would accomplish that and in the colder months set it back to 10
Odd.
I run 1 CPH until we're consistently below 40, then I go to 2 CPH and if we're going to be below 10F I go to 3 CPH.
Works awesome with the EcoSteam.
I'm curious if the cast iron block really cares about large temperature swings. I've got a feeling it doesn't?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Depends ! A lot of boilers with modulating burners have a control called low fire hold. It prevents the burner from going balls out until it warms up nice and slow on low fire.
Makes sense if the boiler were super cold, like in a house where the utililtes have been off and the water is (or has started to) freeze. Other wise, the boiler remains pretty warm anyway between cycles. It takes a few hours for boiling water to cool down. In the case of super cold water, heating cast iron fast can cause fractures and/or cracks. Put a cast iron skillet in the refrigerator overnight and then stick it in a pre-heated oven. It will crack. Put the same skillet in a cold oven and let the oven heat up as the skillet warms, no problem. I know from experience.
How about this, the boiler has a step opening valve on it, Is there a way to keep the valve on the lower setting until the boiler reaches a predetermined temp.0
I really think you're worried about a situation that just isn't a concern. A boiler block (and the water in it) will stay nice and warm for many hours, at least 10 or 12 hours for sure. I've skimmed my boiler over night, about 12 hours with a trickle of cold supply water running into the boiler that whole time and in the morning, the water trickling out of the boiler is still warm. You're just not going to shock that cast iron under typical heating season/shoulder season conditions.Flip said:How about this, the boiler has a step opening valve on it, Is there a way to keep the valve on the lower setting until the boiler reaches a predetermined temp.
