New Installation - 642,000 BTUs in a tight space
JohnNY
Member Posts: 3,324
Twin Aerco Modulex 321 boilers, snow melting, two 100-gallon indirects (in another room, not shown).
Control wiring by Alex "Wire Nut" Marx.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
7
Great job.....wee bit over my head0
Looks good
Way to stuff it all in there.
Must be a really big place.0 -
Yes, its about 10,000 square feet of incredibly luxurious living space on Manhattan's Upper East Side owned by one of the Finance world's biggest names.
And yes, RobG, this is the smallest partitioned room in the house. The shoe closets are much bigger...
Whaddayagonnado?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes2 -
Of course you get the smallest room,who ever thinks of the most important room in house.2- 100 gallon indirects I can only imagine the demand.BTW zone 11(her study) you better hope she never sees that,it's Madame or your ladyship.Great install,how in gods name do you price it?Thanks for sharing.0
Why so much "firepower"? Are there both radiators and radiant floor heating?0
I can see it's not your work but it looks like someone insulated the DWV pipes? Soundproofing maybe?0
Yes, there is radiant heat and perimeter fin-tube. The waste piping insulation throughout the home is indeed sound insulation.
Notice the "indirect" air intake? I like that design by the engineers.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes2 -
Such a small space. My boiler room is 11 x 14.0
John, is that a city multi system heat pump for the place? What zone controls are those? I see you are using the AE200 central control, right?0
"City Multi"?
No, those are two Aerco Modulex boilers. I'm not sure what control that is. @Wirenut did it for me and the HVAC contractor and brought it all together for the BMSystem.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
Looks like a programmable relay type PLC, similar to the Teco. ...and a whole batch of Tekmar stats.0
That definitely looks like a City multi control on the bottom right. Of the control panel.0
Oh, that. Says right on it:
Mitsubishi Electric
Centralized Controller AG-150A0 -
Isn't Citi-Multi the unit that is designed for homes or buildings with allot of glass on multiple sides of the building so that you can run heat and cooling at the same time without dumping the excess heat or cool outside but just displacing it into the other spaces in the building to combat solar gain?0
It's for all buildings. But it's nice because you don't have to run VAV systems and electric or hot water reheats.
It's just less equipment no air handlers not boilers not chillers.
Although boilers hot water base board for perimetor heat his never a bad Idea0 -
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
