Buderus GB142/45
Bill_31
Bill_31 Member Posts: 6
Buderus GB142/45 Installed July 2008---No yearly maintenance until November 2012-- Continual problems from 18 January 2013 until present. Boiler lost manifoilds, air bleeders; condensate was clogged and blocked.
Customer is not happy with our company. To do good maintenance and set boiler up for the coming winter (2015/2016) and gonforward OR replace? Boiler serves 2 radiant zones; 2 hot water basebord zones and 2 indirect dhw tanks
Please comment
The ambassador
  • kcopp
    kcopp Member Posts: 4,665
    Why is the customer unhappy w/ you when the boiler was not maintained? were you supposed to make the appointment?
    Its like a car owner upset w/ the garage when they went 15k between oil changes.....
    What problems are you having w/ the unit?
    What is the water quality like there?
  • Rich_49
    Rich_49 Member Posts: 2,785
    Maintenance issues aside and whose fault it is or is not is irrelevant , between you and the customer .
    Try to clean the heat exchanger using Buderus' method using mineral oil (not spirits) , yes , I have seen that happen . The UBA on that Buderus may be one of the older ones before they recognized a dirty power problem from emergency generators
    ( may not apply ) . Basically everything in that unit is easily replaceable with not much effort . If cleaning this one up is unsuccessful just order the needed repair items and replace without removing piping or unit from wall . Remember to have the water tested also for Buderus GB compliant chemistry and address whatever you find . Use an inhibitor also to protect this piece of equipment from future neglect .
    I would imagine this would be a good learning experience for both the customer and your company about the importance of maintenance .
    732-751-1560
    Rich McGrath 732-581-3833
