Buderus GB142/45
Bill_31
Member Posts: 6
Buderus GB142/45 Installed July 2008---No yearly maintenance until November 2012-- Continual problems from 18 January 2013 until present. Boiler lost manifoilds, air bleeders; condensate was clogged and blocked.
Customer is not happy with our company. To do good maintenance and set boiler up for the coming winter (2015/2016) and gonforward OR replace? Boiler serves 2 radiant zones; 2 hot water basebord zones and 2 indirect dhw tanks
Please comment
The ambassador
Please comment
The ambassador
Why is the customer unhappy w/ you when the boiler was not maintained? were you supposed to make the appointment?
Its like a car owner upset w/ the garage when they went 15k between oil changes.....
What problems are you having w/ the unit?
What is the water quality like there?
Maintenance issues aside and whose fault it is or is not is irrelevant , between you and the customer .
Try to clean the heat exchanger using Buderus' method using mineral oil (not spirits) , yes , I have seen that happen . The UBA on that Buderus may be one of the older ones before they recognized a dirty power problem from emergency generators
( may not apply ) . Basically everything in that unit is easily replaceable with not much effort . If cleaning this one up is unsuccessful just order the needed repair items and replace without removing piping or unit from wall . Remember to have the water tested also for Buderus GB compliant chemistry and address whatever you find . Use an inhibitor also to protect this piece of equipment from future neglect .
I would imagine this would be a good learning experience for both the customer and your company about the importance of maintenance .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
