Weil-McLain
Member Posts: 4,389
This is the oldest one I've seen on my route. Untouched!
Anybody want it, 'cause it's coming out.
1
Someone at least grab that door!Two-pipe Trane vaporvacuum system; 1466 edr
I've got a wine cave in my basement with bare walls. I plan to put all my plumbing and heating memorabilia on the bare walls and ceiling and charge admission.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Yum!0
Very nice....all Californian?Two-pipe Trane vaporvacuum system; 1466 edr
Product of France printed on cases.
Gee.... no screw tops!!0 -
I'd put that door to good use if it is up for grabs.Bob "hot rod" Rohr
Yes, mostly French, mostly reds. Burgundies and Rhones. I like wines with terroir.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I'm not an expert, but shouldn't the bottles on top be facing downwards to prevent the corks from drying out? Do you face them upwards if they are to be consumed soon so that the dregs settle on the bottom?0
Yes, you're right. The ones on top are for drinking soon; their corks should be OK for a short period of time. I never thought about settling the dregs, but that makes sense.
The further down the columns of wines you go, the longer they need to stay in the bottle to mature; some, as much as 10 years. When buying wine that needs to age, I have to think about whether or not I'll be around that long.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I can't help but notice the shipping boxes. Are you part of some type of wine buyers club?0
Yes, although not really a club as far as I can tell. Called Wine Access, they send you special deals; free shipping.
The wine racks are clear Doug Fir, built by a cabinetmaker friend of mine. I traded a Runtal radiator and boiler install for them. Six hundred slots.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
I'll send you the boiler. Keepin' the door.hot rod said:I'd put that door to good use if it is up for grabs.
Two btu per sq ft for degree difference for a slab2 -
Isn't there some kind of law against shipping asbestos across state lines?0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
