Radiator register
See attached photo of a radiator with a convection register.
Several of the radiators in the building were set up this way (plates between the sections) but this is the only one with the actual register damper (at the bottom).
I've never seen this before.
  • RobG
    RobG Member Posts: 1,844
    Interesting, haven't seen that type of contraption before. Do you know if it was manufactured or homebuilt? I love the way the radiator is sitting on the supply pipe and pedestals.
    Steamhead Member Posts: 17,800
    That looks similar to the "box-base" ventilators that appeared in several old radiator catalogs. Was this building used as a school?
    Consulting
  • Chuck_17
    Chuck_17 Member Posts: 148
    Yes. It was originally a school. Now a local historical society museum. The original building was 1838. I don't know when the radiators were installed and I don't know when it was converted to hot water.
