Ever worked for an engineer?
I don't work for them, but I work with 5 of them. We had one that was an expert in thermodynamics but he left a while back.
I don't think they're nuts.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Let me tell you I am lost on a couple of threads lately through no fault of my own when you guys get into the advanced equation stuff.I was absent at school that day when they were teaching it.
Thread from ginahoy is an example.
Take care out there.0 -
Engineering is taught by plastering you with math and physics till you all but fall over. When you get to an actual job your told to forget all that and deal with the real world where many parts have 10 or 20% tolerances; you can get parts with much tighter tolerances but nobody wants to pay for them. Over time you learn where you have to be precise and where you just have to be in the ballpark; you also learn to design in a safety factor that can tolerate some less than optimal part tolorances and thermal drift.
All I ever used was algebra and trig but I used those every day during my career, I never had to dip into calculus - thank God for small favors.
3PSI gauge1 -
I went to this house yesterday to go over the radiant system with the new owner. The previous owner was an engineer and I had been to his house in 2000 to rebuild some B & G Modu-Maid zone valves in the attic.
I meant "nuts" in a good way. The guy set up his house like a laboratory and eventually, only he knew how it worked. I was in admiration of his curiosity and inventiveness. It's just that now, I have to be the one to clean it up. : (8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
I still get calls about how to do somethings dealing with old power supply designs. A few of these will kill you dead if you don't do things right.
My notes made sense to me but not so much to others that might try understanding them.
3PSI gauge0 -
I appreciate engineers that are hands on guys. and with a sense of humor.Bob "hot rod" Rohr
No engineer, no install. No new devices etc.. You need that necessary evil. Every situation is hard to simulate and not cost effective. Without those equations that some genius mathematician developed and some crazy engineer applied we would never have the technology we have. Try designing something without ever actually installing it, understand it in your mind and the math that makes it work (which actually does work...Siggy). Now on the flip side take someones design and see if it works? Totally two different fields and neither to be stepped on.2
I know that new hi-tech inventions have to start with an engineer, but before they get put into practice I believe they have to be field tested and refined by end users and this includes the blue collar workers who install/repair things and sometimes are left holding the bag so to speak. Some manufactures may listen to the issues that field tech people have with their new product and respond with modifications.
Others may not.
It has always been obvious that the people who design any equipment be it a furnace or car have never had to replace or repair anything in it. I have a pick-up truck that needed an air damper door replaced. The entire dash board assembly had to be removed and the steering column disconnected and dropped to the floor for this replacement.....$50 part.......$800 labor (and that was a bargain as you saw what had to be done).
Have anyone tried to tell a person at a mechanical engineering that they have specified a cooling system that is two times too large for the building?4 -
I suspect he was trying to compensate for some night time setback problems. As we know now, on a well balanced system, it is best to set it and forget it.
Modern wireless sensors can be put in several spots, and fire the boiler on an average temperature, or run the system on ODR, and use the thermostat as a high limit.--NBC0 -
My contracting business was in the Napa Valley 30+ yrs ago. It was airline pilots who drove me nuts. Back then they had money and time. I'd do banks of sensors on solar systems and I get a call. "Jack, it seems my average temperatures are off by 1.5-2* this year to last..." The discussion could go on and on.
I got so I'd qualify my customers, asking "what do you know about these type systems and what do you want to know?" It kinda let me know where we were going.0 -
I helped an engineer/friend on a total house remodel. He wanted to cool a 2,000ft2 house with no ductwork. I said fine, let's do radiant cooling and a small one-supply/one-return air handler for humidity control. No good, he wants to size the system to handle up to 30+ people when he has guests over. Oh, and he needs to compensate for the waterfall he planned to install in the living room. So, I would need like 3/4" tubing on 3" centers throughout walls and ceilings to make that happen. I must have spent 5 days just talking about the system. Never picked up a single tool to do any work.4
Here, every piece of paper that an engineer signs, must have "Ing" (French short for engineer) after his name or as we say: Intelligence Not Garanteed!0
I may do it for my own house at some point. I have a ranch, which makes it incredibly easy to install tubing in my ceilings. I'll then use my existing A/C air handler with a water-coil for dehumidification, and a reheat coil off the compressor. I never got around to finalizing the control scheme but it would most certainly rely on humidity/dewpoint sensors throughout the house.Hatterasguy said:
Not all of them are that stupid.JStar said:I helped an engineer/friend on a total house remodel. He wanted to cool a 2,000ft2 house with no ductwork. I said fine, let's do radiant cooling and a small one-supply/one-return air handler for humidity control. No good, he wants to size the system to handle up to 30+ people when he has guests over. Oh, and he needs to compensate for the waterfall he planned to install in the living room. So, I would need like 3/4" tubing on 3" centers throughout walls and ceilings to make that happen. I must have spent 5 days just talking about the system. Never picked up a single tool to do any work.
BTW, have you done any radiant cooling (with reasonable expectations)? How did it work out? What controls did you use to prevent condensation?0 -
It's less of a justifiable project and more experimental.Hatterasguy said:Hard to justify such an installation (unless you're possessed) if you already have the forced air ductwork.
I'm thinking about it for some new construction but the costs are a bit high and it's not without a bit of risk. Looking for additional insight.0 -
I would rather receive a painful answer than no answer at all. In that way, I'll gladly pursue any possessed thought experiment that I please. At least in my own home, I can make those mistakes first, learn the right way, and then later boast that I knew the correct methods all along. Right now, there is more myth than method to residential radiant cooling and I would like to see it in action firsthand.Hatterasguy said:
I'm thinking about it for some new construction but the costs are a bit high and it's not without a bit of risk. Looking for additional insight.2 -
Yeah,Hatterasguy said:
I can fully agree with that. I'm running an "experiment" right now that nobody in the profession would agree with. We'll see how it goes.JStar said:
Regarding residential radiant cooling, you're absolutely right. There is precious little information available as to the ultimate success or failure for such an approach. We are in a climate, however, that could be quite successful as the design day summer temperature is not excessive. The entire approach hinges on removal of the latent with a system that doesn't make too much noise and doesn't consume any space.
Kinda like undersizing your boiler and almost everyone telling you it won't work. Dave Brunnell, I salute you.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
JStar also likes to help others pursue their own possessed thought experiments. Just look in my basement.JStar said:I'll gladly pursue any possessed thought experiment that I please. At least in my own home, I can make those mistakes first, learn the right way, and then later boast that I knew the correct methods all along.
1890 near-vapor one pipe steam system | Operating pressure: 0.25 oz | 607 sf EDR
Midco LNB-250 Modulating Gas Burner | EcoSteam ES-50 modulating controls | 70 to 300 MBH |
3009 sf | 3 floors | 14 radiators | Utica SFE boiler | 4 mains, 135 ft | Gorton & B&J Big Mouth vents4 -
Except you run too high of a pressure.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Only if you consider 1/2 to 7/10ths of an inch of water column "high".ChrisJ said:Yeah, Except you run too high of a pressure.
3009 sf | 3 floors | 14 radiators | Utica SFE boiler | 4 mains, 135 ft | Gorton & B&J Big Mouth vents0 -
Your system is splitting at the seams!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I still keep pondering ditching the drafthood for a barometric damper if I ever have any money. I can dream, can't I?JStar said:Let it be known that I will happily endorse any idea worth having, if only for the sake of having that idea. We are fire-tamers. We are the ageless magi seeking to control the elements. Who could oppose that?
I might know somebody who is closing his business and looking to get rid of a lot of parts, including a handful of draft controls. I just can't remember his name...................ChrisJ said:
3 -
Awesome! Goodbye drafthood!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I work for engineers regularly. They are the easiest for me to work for as they appreciate accurate mathematics.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating3 -
I don't mind helping them because they are so overworked that if you give them a CAD drawing they will just cut and paste my design into the drawings, pretty much locking me into the job. It works out for both of us, and he gets to buy ME lunch.Charlie from wmass said:I work for engineers regularly. They are the easiest for me to work for as they appreciate accurate mathematics.
My beef with engineer clients is that often they critique and trash talk components and methods because they don't conform to thier sometimes unrealistic and impractical standards. Not all, but enough to want to give them a wide berth!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
