New Yorker CLW 3-P
rayriz1981
Member Posts: 4
in Oil Heating
You won't until you dive in. Be prepared for the worst- boiler replacement if the block mating surface is pitted beyond serviceable.. Plan for drill/tapping. Kroil up those bolts and say yer prayers!0
I got the bolts off and a plate in the gasket now that it's open how do I know the coil it's cracked or busted0
What coil? That looked like a coil blank off plate. Are you talking about the boiler block?0
that's what I understand I didn't see a coil so there's no coil to change it's just the plate thank you0
Glad it worked for you, that looked ugly!
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
