direct vent, non condensing, tankless?????
RLuck
Member Posts: 24
Does any one make a direct vent, non condensing, natural gas tankless waterheater?
yes takagi
tk jr, tk3 tk4 and tm-50
Or should I just use an electric tankless. It's for a small church, bathroomx2, small kitchen, and a large baptismal POOL that is occasionally used. The issue is filling the pool, about 300 gallons.0
where are you located?
that determine the price of gas verse electric/0 -
Not a fuel cost issue. Building layout issue, no chimney and no nearby location to send the condensate to. Plus the odd demand, they want a solution for filling the large baptismal POOL.0
is there an outside wall with gas pipe ? filling the pool be no problem where are you located0
Thanks, takagi makes what I need, just have to add direct vent kit.0
What is your location? If you are in an area that is not subject to freezing you could mount it on the exterior of the building.0
- 50 Industry Classes
