direct vent, non condensing, tankless?????
RLuck
RLuck Member Posts: 24
Does any one make a direct vent, non condensing, natural gas tankless waterheater?
  • Snowmelt
    Snowmelt Member Posts: 1,454
    yes takagi
    tk jr, tk3 tk4 and tm-50
  • RLuck
    Or should I just use an electric tankless. It's for a small church, bathroomx2, small kitchen, and a large baptismal POOL that is occasionally used. The issue is filling the pool, about 300 gallons.
  • Snowmelt
    where are you located?
    that determine the price of gas verse electric/
  • RLuck
    Not a fuel cost issue. Building layout issue, no chimney and no nearby location to send the condensate to. Plus the odd demand, they want a solution for filling the large baptismal POOL.
  • Snowmelt
    is there an outside wall with gas pipe ? filling the pool be no problem where are you located
  • RLuck
    Thanks, takagi makes what I need, just have to add direct vent kit.
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    Rinnai makes a non condensing tankless water heater too.
    jonny88
  • RobG
    RobG Member Posts: 1,843
    What is your location? If you are in an area that is not subject to freezing you could mount it on the exterior of the building.
