panel rads vs curtains
hws
hws Member Posts: 43
Hello all,
Looking for some opinions here. I just installed Stelrad panel radiators throughout my house. My wife raised the concern that with our long curtains touching the rads, burning or melting of curtain fabric may result. I'm not sure on the issue myself, haven't run into it on previous jobs (had to be my own house, right?). Anyone have any experience with this?
Thanks in advance.
  • RobG
    RobG Member Posts: 1,844
    I wouldn't worry about it, One of the ways to temper down a steam or hot water radiator is to put a blanket over it. If your wife is worried, have her bust out the sewing machine and do some hemming.
  • kcopp
    kcopp Member Posts: 4,628
    That is a left over old wives tale relating to electric baseboard heat...... not a concern at all.
    hot_rod Member Posts: 26,579
    The panel radiators do need to have air circulation across them, be sure the curtains don't block the convection current across the panel.
    kcopp
  • vaporvac
    vaporvac Member Posts: 1,520
    I might also opt for natural fibres on the drapes with a higher melting temp.
  • ChrisJ
    ChrisJ Member Posts: 17,068
    I've had curtains touch my steam radiators.
    No issues.
    I wouldn't even give it a thought with hot water. But as has been said, don't let the curtains stop the draft. It won't hurt the curtains, but it may hurt your wallet and or comfort.
