watercop
jonny88
jonny88 Member Posts: 1,139
hi,has anyone used watercop or similar devices for whole house protection.If so how would you rate it and any callbacks for sensor failures shutting down house.Thanks
  • AlCorelliNY
    AlCorelliNY Member Posts: 63
    Have one installed for years at one site. Gets tested every year. Works great.
    Al Corelli
  • Zman
    Zman Member Posts: 7,610
    Flo Logic makes nice one that measures flow rates and turns off when certain trends exist.
    It can notify the alarm system,has a home/away mode and has a bypass feature for irrigation controls.
    I have a few of them out there. Have had one bad battery alarm and more than a couple irrigation company misunderstandings (Yes you do need that wire on the master valve terminal) .
    If you have leaky toilets, It will let you know.
    I do like the product.
    Carl
    Albert Einstein
    jonny88BobbyBoy
  • jonny88
    Thanks guys for the feedback.Just was looking for real world installs and quirks which you may of had,again thanks for taking the time
