watercop
Have one installed for years at one site. Gets tested every year. Works great.Al Corelli0
Flo Logic makes nice one that measures flow rates and turns off when certain trends exist.
It can notify the alarm system,has a home/away mode and has a bypass feature for irrigation controls.
I have a few of them out there. Have had one bad battery alarm and more than a couple irrigation company misunderstandings (Yes you do need that wire on the master valve terminal) .
If you have leaky toilets, It will let you know.
I do like the product.
Albert Einstein2 -
Thanks guys for the feedback.Just was looking for real world installs and quirks which you may of had,again thanks for taking the time0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
