A great boiler room by our lead installer.
tim smith
Member Posts: 2,928
Just wanted to give kudos to our lead mechanic on this job along with all the others he does for us. His quality speaks for itself.
3
Nice work.
What's your locale? I'm curious because of the sisemic strapping on the tanks.Bob Boan
Ironman, we are in Seattle.0
Cascadian Subduction Straps?
Nice work. Whose expansion tank brackets are you using?0 -
SWEI
we just shorten qs50 strap kits for water heaters, simple and not too much cost.0 -
Thanks -- I'll look into that. We've used 12-14" strut clamps and welded on extensions to others, but the price of the dedicated expansion tank mounts is a tad rich for some jobs.0
Very nice work, great to see.
Kurt, can you really build or modify a strap for less than this HydroClaw?
I know some of the supply houses keep them on the shelves also.Bob "hot rod" Rohr
That price makes much more sense (though the one for 11" tanks is about $10 higher.)0
these #12 are around 16 bucks. Nice stuff from Holdrite. I've used their copper stub out brackets for many years.Bob "hot rod" Rohr
I use the Hydro-Claw. Love it.Steve Minnich0
very nice install in a tight space (as always).Nice to see someone still solders.Thanks for sharing0
If I remember correctly, the hydroclaw was invented by a wallie. Don't remember the name though. I use it and like it.0
I am always proud of the work Aaron does. you never have to say why didn't you run that level, straight or plumb.0
One of our good plumber installs. Imade a sketch of the required piping and Sylvain did the rest. It has 23 zones of radiant, suplementary duct heater, domestic hot water, 400,000 BTU pool heater. Boiler is a KBN399. It is a friends house.0
If you're going to post your work, why not take an ad out?
It helps people find you. I get work from it all the time.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Henry, nice looking job also.0
- 50 Industry Classes
