A great boiler room by our lead installer.
tim smith
tim smith Member Posts: 2,918
edited May 2015 in THE MAIN WALL
Just wanted to give kudos to our lead mechanic on this job along with all the others he does for us. His quality speaks for itself.
4JohnpipeRobGRon Jr._3
  • Ironman
    Ironman Member Posts: 7,894
    Nice work.
    What's your locale? I'm curious because of the sisemic strapping on the tanks.
    Bob Boan
  • tim smith
    Ironman, we are in Seattle.
  • SWEI
    SWEI Member Posts: 7,348
    Cascadian Subduction Straps?
    Nice work. Whose expansion tank brackets are you using?
  • tim smith
    SWEI
    we just shorten qs50 strap kits for water heaters, simple and not too much cost.
  • SWEI
    Thanks -- I'll look into that. We've used 12-14" strut clamps and welded on extensions to others, but the price of the dedicated expansion tank mounts is a tad rich for some jobs.
    hot_rod Member Posts: 27,182
    Very nice work, great to see.
    Kurt, can you really build or modify a strap for less than this HydroClaw?
    I know some of the supply houses keep them on the shelves also.
  • SWEI
    edited May 2015
    That price makes much more sense (though the one for 11" tanks is about $10 higher.)
    these #12 are around 16 bucks. Nice stuff from Holdrite. I've used their copper stub out brackets for many years.
  • Steve Minnich
    Steve Minnich Member Posts: 2,869
    I use the Hydro-Claw. Love it.
    Steve Minnich
  • jonny88
    jonny88 Member Posts: 1,139
    very nice install in a tight space (as always).Nice to see someone still solders.Thanks for sharing
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    If I remember correctly, the hydroclaw was invented by a wallie. Don't remember the name though. I use it and like it.
  • tim smith
    I am always proud of the work Aaron does. you never have to say why didn't you run that level, straight or plumb.
  • Henry
    Henry Member Posts: 998
    One of our good plumber installs. Imade a sketch of the required piping and Sylvain did the rest. It has 23 zones of radiant, suplementary duct heater, domestic hot water, 400,000 BTU pool heater. Boiler is a KBN399. It is a friends house.
  • JohnNY
    JohnNY Member Posts: 3,351
    If you're going to post your work, why not take an ad out?
    It helps people find you. I get work from it all the time.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • tim smith
    Henry, nice looking job also.
