Kitchen Faucet Problem
There's some kind of diverter but I never understood how it works other than when the sprayer is open, it automatically goes to that.
Can you shut the sprayer off, or is the spray handle stuck on some how? If so, that will cause it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Might be crud, gravel, sand built up inside the diverter. You could get lucky by removing the whole assembly and blowing compressed air & water backwards thru the sprayer line and faucet. Don't exceed normal water pressure, I'd keep it lower when blowing reverse.0
Gotta make and model? Is this a faucet with separate sprayer, or a pull out faucet with a spray/stream diverter?0
Sounds like a delta0
Guys, the original post was 6 or 7 weeks ago. OP hasn't been back in a while0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
