Kitchen Faucet Problem
Carmine
Carmine Member Posts: 10
Water is only coming out of sprayer when activated. Nothing is coming out of spout on either hot or cold water handles. Is there a cartridge under each handle? Is there a diverter under the main spout?
  • Fred
    Fred Member Posts: 8,542
    There should be an airator on the main spout that screws onto the spout. It is probably clogged up. See if you can unscrew it and run the water. If it runs,clean the airator out or put a new one on.
    Charlie from wmass
  • ChrisJ
    ChrisJ Member Posts: 17,333
    There's some kind of diverter but I never understood how it works other than when the sprayer is open, it automatically goes to that.
    Can you shut the sprayer off, or is the spray handle stuck on some how? If so, that will cause it.
  • Patchogue Phil_2
    Patchogue Phil_2 Member Posts: 316
    Might be crud, gravel, sand built up inside the diverter. You could get lucky by removing the whole assembly and blowing compressed air & water backwards thru the sprayer line and faucet. Don't exceed normal water pressure, I'd keep it lower when blowing reverse.
  • Gordy
    Gordy Member Posts: 9,546
    Gotta make and model? Is this a faucet with separate sprayer, or a pull out faucet with a spray/stream diverter?
  • j a_2
    j a_2 Member Posts: 1,804
    Sounds like a delta
  • Fred
    Guys, the original post was 6 or 7 weeks ago. OP hasn't been back in a while
