Looking For A More Efficient Strainer
JStar
Member Posts: 2,752
We have a job with a steam boiler that also serves a hot-water loop for an indirect tank. The system has some deterioration out in the piping and the current brass y-strainer clogs up on a very regular basis. Is there a better strainer out there? Am I better off putting two strainers in parallell? Using a strainer that's a few sizes bigger than what's there now? And other ideas?
I was looking at Caleffi's DirtMag but it might be too tall. I have limited height. Although, for the right product, I would alter the piping.0
i have had great success with dirtmag great product
Sounds like you might be best served with a separator. They catch the particles and allow them to fall to the space at the bottom. The flow and pressure drop doesn't change as they do their job.
There are some vertical versions if that would help.Bob "hot rod" Rohr
Living the hydronic dream1 -
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0CEYQFjAE&url=http://www.rosedaleproducts.com/&ei=qnhPVcjyHNPAgwTwooGIBA&usg=AFQjCNGLv_qhVz57eUwE_4KvFpAYKAPEEA&bvm=bv.92885102,d.eXY
Check out Rosedale Products. They have every kind of filter strainer, basket, bag filter etc you could want. They know there stuff. You can buy direct with a crdit card0
- 120 Geothermal
