Anyone use RubyFluid?
ChrisJ
ChrisJ Member Posts: 17,070
edited May 2015 in THE MAIN WALL
I thought I asked this years ago but can't remember what was said and couldn't find the thread.
Does anyone use Rubyfluid on potable water lines or plumbing / HVAC in general?
I can't really find any information on it, and it says one of it's applications is plumbing. Of course it says it's toxic but so does every paste flux.
http://www.superiorflux.com/spec/TDS_RubyFluid.pdf
http://www.superiorflux.com/rubyfluid_flux.html
Seems like it would be a lot easier to apply small amounts than a paste. Just put some on a small rag or brush and put a minimal amount on your fitting and pipe to make a clean joint.
I had some I used to do some soldering on the radiator in our company's Ford model A and it worked great.
