aluminum plates
plumbgod
plumbgod Member Posts: 9
what is anyones thought on alumimum transfer plates placed in rock mortar? Will the mortar eat at the plates over time? Please let me know any thoughts on this.
  • 4Johnpipe
    4Johnpipe Member Posts: 492
    What is the reason for that? Heat transfer plates are designed to be in direct contact with the tubing to allow conduction to take place. This would increase the higher tempurature surface area which is in direct contact with a wood subfloor where conduction can take place to the wood over a greater surface area. I would check with a manufacturer of the plates. There are several quality plates.
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • Rich_49
    Rich_49 Member Posts: 2,783
    You would be better off having .389 tons of aluminum ground up into 1/16" aggregate and mixing it with the appropriate amount of concrete for a 1000 sq ft x 2" thick pour , install tubing as you would in an embedded pipe application .
    I am only kidding .
    732-751-1560
    Rich McGrath 732-581-3833
    SWEIjonny88
  • plumbgod
    this is for a snowmelt app. customer has a 1 foot over hang and no way to get to attached to it. so we thouth of plates.
  • Rich_49
    1 foot hangs over what ?
    732-751-1560
    kcopp
  • Steve Minnich
    Steve Minnich Member Posts: 2,964
    Is this for ice damming on a roof by chance?
    Steve Minnich
  • RobG
    RobG Member Posts: 1,843
    Have you thought about electric for the overhang? If someone can afford snowmelt they can afford a system with two heating mediums.
  • Steve Minnich
    If it is for ice dams, I agree with Rob.
    Steve Minnich
