aluminum plates
plumbgod
Member Posts: 9
what is anyones thought on alumimum transfer plates placed in rock mortar? Will the mortar eat at the plates over time? Please let me know any thoughts on this.
What is the reason for that? Heat transfer plates are designed to be in direct contact with the tubing to allow conduction to take place. This would increase the higher tempurature surface area which is in direct contact with a wood subfloor where conduction can take place to the wood over a greater surface area. I would check with a manufacturer of the plates. There are several quality plates.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
You would be better off having .389 tons of aluminum ground up into 1/16" aggregate and mixing it with the appropriate amount of concrete for a 1000 sq ft x 2" thick pour , install tubing as you would in an embedded pipe application .
I am only kidding .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38332 -
this is for a snowmelt app. customer has a 1 foot over hang and no way to get to attached to it. so we thouth of plates.0
1 foot hangs over what ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Is this for ice damming on a roof by chance?Steve Minnich0
Have you thought about electric for the overhang? If someone can afford snowmelt they can afford a system with two heating mediums.0
If it is for ice dams, I agree with Rob.Steve Minnich0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
