Heat Loss calculator
chris87
Member Posts: 9
Does anybody have a good link/program for a good heat loss calculator to size a heating system? Thanks
http://www.slantfin.com/homeowners-page/ipadapp.html is a good place to start.0
Only complaint I have with the Slant/Fin program is that you cannot give the windows a cardinal direction. You posted this in the steam section. Are you replacing a steam boiler? If so, a heat loss is not necessary. You'll need to measue radiators to get the correct boiler size.0
Opps didn't mean to post this in steam, no its natural gas hydronics. Thanks for the calculator much appreciated0
If you need help, I've been known to do heat load calculations for people.0
I'm curious. Are most guys recommending Slant-Fin's calculator because it's readily available for anyone to use? And free?Steve Minnich0
That, plus the fact that it's potentially comprehensible for a homeowner.Stephen Minnich said:I'm curious. Are most guys recommending Slant-Fin's calculator because it's readily available for anyone to use? And free?
Gotcha. Makes sense.Steve Minnich0
What do you recommend?Stephen Minnich said:I'm curious. Are most guys recommending Slant-Fin's calculator because it's readily available for anyone to use? And free?
It's free, it works, it's accurate. Works for me0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
