Panel Radiators in Log Homes
Harvey Ramer
Member Posts: 2,281
They are a little tricky to get mounted on those logs but I think they look good.
4
Beautiful! Do you mind if I use this to show my customers what the panels look like on the wall? Buderus has a good catalog however it seems to be aimed at the contractor verse the customer.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com1 -
Nicely played! It's a craft to install a flat metal rad on a curved surface. That is a great heat emitter for log construction.
Also log structures can be tough to heat and get an accurate load number, infiltration never sleeps, and the ever shrinking logs need yearly inspection and caulking updates.Bob "hot rod" Rohr
Living the hydronic dream1 -
Looks great, I have a 1921 soft maple log home I will be working on this summer, if the builder ever gets the roof insulated and finished. I get to play with natural log shape, yay fun!
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Beautiful. ..I've put a lot of The Buderus panel rads in....and never a problem. ..high qaulity. Mad Dog1
I worked with a great log builder in Utah. He would mill, or flatten the bottom log so we could mount fin tube baseboard nice and plumb and rigid. It also stepped it in a bit for protection.Charlie from wmass said:Looks great, I have a 1921 soft maple log home I will be working on this summer, if the builder ever gets the roof insulated and finished. I get to play with natural log shape, yay fun!
He would do it with the chainsaw if we had the location to him early enough. He also had some custom routers that he could put the flat area after the logs were stacked.Bob "hot rod" Rohr
@Hotrod I was going to use Sammy screws and 3/8" rod to put the brackets on a flat plain. Your idea far is better for a new home or a job with a proper log home carpenter. I am pretty sure these old Maple logs would give me more fight than I would want.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
