Indirect tank build
hot_rod
Member Posts: 27,212
I was able to stuff 50 feet of 3/4" TracPipe, less the jacket, inside this ThermoCon buffer tank.
I'll reduce the 2" ports to 3/4 with brass bushings and use the TracPipe termination fitting., Amazingly all but one loop stay in the bottom 1/2 of the tank as I pushed it in.
I suspect any tank with 2" connections near the bottom could be converted to an indirect. Most of the DHW storage tanks had dual 2" ports near the bottom.
Very minimal amount of blood loss also
Where's the best place to get a deal on one of these tanks?0
I need them with a top and bottom fitting for a reverse indirect config. Not sure how I would keep the CSST from falling to the bottom, though...0
B-Rob, these are tanks that had a bad experience with a forklift. Normally we scrap them, but I wanted to try putting CSST inside one. I have a dented 25 gallon you are welcomed to, if you want to pay freight from Springfield, MO.
Kurt, There really is no way to control the way the tube coil inside. Some loops go around, a few up and down. I doubt they will move around inside, it's pretty stiff tube.
For a reverse indirect I think you would want two or three 60 foot loops, headed together to keep pressure drop down.
The smallest Ergomax has about 20 sq. ft of HX surface, the largest around 60 sq.
Not sure how that calculates when using corrugated tube, compared to smooth copper.
While stainless is not as good as a conductor as copper, I think the corrugations would add surface area and better turbulence inside. Many of the Euro tanks are using corrugated ss now for HXers.Bob "hot rod" Rohr
Both true.hot rod said:Not sure how that calculates when using corrugated tube, compared to smooth copper.
The lower conductivity of stainless is at least partially offset by its increased tensile strength. For an equivalent pressure rating, copper tube will require a much heavier wall section than stainless will.0 -
i think the decrease in conductivity is a mute point with thinner wall section, and the corrugations. Be interesting to see the performance.0
I wonder how the friction will affect the lifespan of the tubing as it was designed for gas? Then again it could always be re-tubed.
HR, didn't you use Trac-Pipe inside the dog radiator? How is that holding up?0 -
Thanks for the offer! How dented is dented? Any chance there is around a 55 gallon laying around dented and sad?hot rod said:B-Rob, these are tanks that had a bad experience with a forklift. Normally we scrap them, but I wanted to try putting CSST inside one. I have a dented 25 gallon you are welcomed to, if you want to pay freight from Springfield, MO.
Turns out the CSST gas tubing is the same tube as solarflex and inside many indirect tanks.
It's also used in industrial applications for high pressure fluids, like hydraulics and compressed air and gases. It has a long track record for high pressure applications. I believe it's used in aircraft construction ak
My radiant concrete dog with a CSST heart has been running non stop for around 22 years nowBob "hot rod" Rohr
Living the hydronic dream1
- 116 Geothermal
- 169 Indoor-Air Quality
