replacement board needed for automated logic board
zepfan
Member Posts: 467
does anyone know of an I/O board that is BAC Net compatible,and can be installed in an existing staged, 4 compressor ac unit? we have a unit that has a defective Automated logic I/O point expander board part #x8160s.The problem is the board is no longer made by the manufacturer, and the equipment manufacturer has a retrofit kit that is super expensive.A new unit could be bought for how much they want for the kit.There has to be a board made by someone that has 8 digital outputs,11 analog inputs, and 5 digital inputs.If anyone has ran into this situation,please post. Thanks to all.
I would post that question here in this controls forum if you don't get any help.
http://hvac-talk.com/vbb/forumdisplay.php?26-ControlsThere was an error rendering this rich post.
Are you sure that The Automated Logic board is part of the equipment?? Or is it a control board installed by the control contractor?
Don't know where your located but the Automated Logic dealer in MA. is Yankee Technology, Ludlow, MA Moody street 1-413-547-6595. If you strike out there you may have to retrofit someone else's board.0 -
It is part of the equipment, when I contacted York they were well aware of the board, and the fact it was no longer made by Automated Logic.0
Well, that sucks. How old is the unit?0
A point expander will be tethered to a controller of some sort. Is the controller present and working? Your best bet would be to find a used or NOS replacement.
If ALC does not currently make a compatible expander, you will need to migrate the programs and config from the old controller to a new platform (or start from scratch and write new code.)0 -
The unit is only 9 years old.That is what we are looking at now is gutting the units controls, and installing new controls.Probably orion controls0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
