munchkin f-18 code
haventseenenough
Member Posts: 61
in Gas Heating
I have a Munchkin 199m series 2 the faults out on a gas valve code. The control board is a 925 controller, the gas valve has been replaced with the wiring harness. New flame sensor and ignitor. Good condensate drain. It still faults out.
Any clues?
Thanks Haventseenenough
Any clues?
Only thing on the flowchart you haven't done is the control board.0
When was the last time it was cleaned and a combustion test done? I would also monitor voltage to see if you are getting any drop in voltage that would answer the control board issue. The 926 board has a beefed up transformer.0
Check for good solid grounding.Al Corelli0
