B&G Airtrol Boiler Fitting
Dave0176
Member Posts: 1,178
Got a question, can't seem to find anything about it on B&Gs website, did they discontinue manufacturing it? The only place that I find them for sale is in ebay.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Thanks SWEI that's all I find is the tank fittings, not the boiler fittings. I suppose I'd just be able to use the in-line air seperater.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
They currently show just the In-Line Airtrol and the Rolairtrol in the catalog.0
They stopped making the boiler fittings years ago. The boilers got too small for them.Retired and loving it.0
Thanks Dan, I reason for asking is because B&G literature for the Airtrol tank fitting still says to use an oppropriate Airtrol boiler fitting.
I m doing a boiler replacement that has a steel compression tank. After reading pumping away I'm going to install the proper fittings and the tank will be fine.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Taco still makes an air scoop with a 3/4" tapping in residential sizes and 1" tapping in larger sizes which can be used to run to an airtrol tank fitting. They also have an 1/8" tapping for a float vent, just plug it when using a compression tank.
I've used them a few times, they work perfectly together when pumping away.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 998 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
