drilling pvc vent pipes for combsution tests
GW
Member Posts: 4,693
in Gas Heating
I am having the darnedest time trying to find a drill-tap combination tool, does anyone have a source for these?
Gary
Gary
What size? I know the Greenlee DTAP comes in 1/4-20.0
McMaster-Carr......combination drill bits/taps0
do they make a 1/4 npt?
I can't find one large enough at McMaster Carr.
I will look at GreenLee.
Thanks.0 -
Have not seen them in NPT sizes. A truss head bolt will work in PVC, though I would prefer fine threads.
We have used 1/4" thread-serts in single wall vent pipe.0 -
Worse comes to worse......North American Tool
Phone: 800.USA.TAPS (872.8277) • 815.389.2300
Fax: 800.USA.FAXX (872.3299) • 815.389.2952
They have NPT.0 -
Thanks. I will look at these on the big screen tomorrow0
Whose boiler are you using that does not give you a place to test the boiler?0
Mostly furnaces, yes most every boiler has ports0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
