magnesium anode bag
bob young
bob young Member Posts: 2,177
ANY OF OUR EXPERT PROS HAVE ANY EXPERTISE WITH MAGNESIUM ANODE BAG INSTALLATION FOR STEEL PIPING UNDERGROUND PROTECTION. THANX, BOB YOUNG
  • JUGHNE
    JUGHNE Member Posts: 11,548
    Talked to the local gas guy here, he said he has only read about bare steel UG gas systems that have anode protection. But because of the bare steel in contract with the earth the anodes are used up quickly unless it is an "active" system with a power supply involved. We have the coated/insulated NG system here with passive anodes.
    A gas company should be able to point you in the right direction.
    bob young
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,082
    Hello: You might want to have a look at NACE http://www.nace.org/home.aspx and see if they have any info available. A general overview from Wikipedia http://en.wikipedia.org/wiki/Cathodic_protection might be useful too. Part of installing a groundbed correctly is to make sure the anode/s can function by having a reliable path for current to follow. Here also is some useful info. http://www.delweg.com/cppapers/cpsystem.htm
    Yours, Larry
    bob young
  • bob young
    THANX, LARRY
