5 year old geothermal system water wil not shut off after heating cycle
thedealmakinman
Member Posts: 1
in Geothermal
I just discovered the water runs continuously after a heat cycle. if I turn geo off the water will turn off normally. when turned back on the water will ramp up normally in about 1 minute, then the geo fires up about 4 minutes later. BUT, when cycle is finished the geo shuts down normal, and the water continues to flow. My light bill last month was $400! I suspect the taco valve on the incoming water supply. Any suggestions?
Yes seems like your Taco won't close, pull off the top-most wire and make sure it's not a control issue.
Gary0 -
Sound like a control issue if the valve closes after you turn the power off. Try taking the wires off the valve and see if the valve closes . If it does you must be getting voltage from the board in the heat pump and the valve is good. Remember that the TACO valves are a slow closing type of valve so it will take awhile .0
If you need assistance with a control I would be happy to help. HBX does offer a geothermal control and a zone module which can control when your equipment is on or off and for how long.Comfort
Control
Innovation0
- 15.8K Strictly Steam
