CONDENSATE RETURN
bob young
Member Posts: 2,177
A below grade condensate return running between two buildings failed . it was not sleeved properly for protection from soil conditions but it also was only 24 " below grade. nyc frost line is 42 " i think it also may have froze between cycles. what say the experts ? i recommend replacement but below frost line. bob young nyc lic. plbr.
Sounds like the right plan. Will the boiler waterline co-operate?
I would consider using Aquatherm for that application if it were my job. Get the application blessed first (they need some assurance the line will never carry steam) and you get a ten year warranty, including labor and any peripheral damage.0 -
I would also consider the use of Niron from Nupi.
Similar to Aquatherm, but a better class of resin and it carry's a 30 year warranty over the 10 year warranty. I have been reading up on it and it's PP-R on steroids.0 -
If it's a wet return I'd stay below frost line. Any way you can make that return dry?0
Wet return=below frost. Dry return ok with proper pitch. personally I wouldn't risk the liability of plastic pipe. traps always fail0
