looking for tubing layout
clueless69
Member Posts: 2
i just built a 36x54 pole barn . where do i find info on how to layout zones and how much is needed for the project. i am clueless in this radiant heat process.
Stephen Minnich said:
Based on what you've said, the best I could offer is to use the "Find a Contractor" on this site. IMO, anything short of bringing in a contractor who is well versed in design, service, and installation of a radiant panel system is a poor decision.
To elaborate on what Stephen said above, there is a lot more information needed to provide you with any assistance. There is much more to a radiant system than just a tubing layout. Have you performed a heatloss yet?0 -
Hey clueless where from0
western new york. outside of buffalo. i can't imagine much heat loss considering i had the best insulated doors and windows installed . i also had the whole building insulated and ceiling blown in with insulation also.0
Contact Rich who is on here sure he can lead you in the right direction0
Sounds like you just require some basic help . Contact me if you'd like and if you're more comfortable with someone close to you I can locate the right guy for you also .in your area .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
