Looking for Convection Type Radiator Cover.
MaryJH
Member Posts: 4
I am looking to buy a convection type radiator cover for a house that was built in 1950. (new or used) The cover I have now was cut to go behind a cabinet and I would like to remove the cabinet and expose the entire radiator. But unless I can find a replacement cover I cannot.
The cover is metal and snaps into place. I need one that is 48/49 inches long. I have attached a picture of the type of cover I am looking for. If anyone on here thinks they may know of one from a remodel or where you can buy similar replacements please let me know.
Thanks for any help ....
Have you checked the "Buy, Sell, Barter" tab on the right under Catagories? May be something there.0
Also check out craigslist for your area and maybe even eBay.0
Thanks....I did post on Craig's List. I will look and see if some is selling and I will click the tabs..thanks0
Here you go! What timing!
http://forum.heatinghelp.com/discussion/154121/70-faceplates-and-registers#latest1 -
Thank you KC_Jones. I am not sure I posted to the right place to get more info. New at this...
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
