Common venting multiple mod-cons? Which brands allow?
JohnNY
Member Posts: 3,338
Not WM. Not Peerless. Not Lochinvar....
Of course you can with an engineered Exhausto system and the like, but I thought some manufacturers were coming around to allow for common venting of two or more boilers without outside mechanical assistance.
Am I dreaming?
Am I dreaming?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Bosch GreenStar, Buderus GB162, and I think Navien and TT when their racking system is used. But all of that is going from memory which is very good, but also getting very short.
The trick is that the controls can bring the fan on with each one without firing the burner until needed.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.-1 -
Lochinvar does allow common venting as the Crest is certified for Cat II. After 7 years of hard work, our B149.1-15 code allows common venting of Cat IV if the manufacturer has instructions on how to do it. Also only the same equipment of the same capacity can be common vented.0
Not big on common venting. Maybe it can save a few bucks on some jobs, but may not be worth the potential problems.jmho0
Viessmann does. PM me if you want the docs -- I'm not sure they're on the website yet.
Triangle Tube only on 399's -- I spent weeks going back and forth with their engineers and Centrotherm trying to get approval for two 250's and a 110, but ultimately failed.
I would ask the venting manufacturers -- they keep pretty good track of who has approved what.0 -
Well that's a mess, but yes, that's the general idea.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes2 -
What's holding up the venting the appliances?0
HTP allows on many units and even manufactures a few with multiple combustion assemblies with a common vent .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
OOoooh. Look at that! Nice.
Classes1 -
That's wasn't me I did the tankless only0
Yeah, I think (at least I hope so) that everyone knows that.Snowmelt said:That's wasn't me I did the tankless only
