water loss
bubbad
Member Posts: 15
have no visible leaks,that i can find,all piping is visible,PB says evaporation rate of .15 gpm,boiler holds 9.3gals.don't see any steam from chimney,i estimate i add about a gallon to a gallon and a half per week,running t-stat @ 69 degree 24/7,done everything but flood boiler to check for leaks.i'm trying to be sure if this adding this water is normal or do i have a problem,other than water loss everything seems great
Any hidden, underground wet returns? No leaking unions? All radiator valve packing and spud nuts are not leaking?0
no underground returns ,no leaks that i can find0
Are you estimating that or does your feeder have a counter.0
how did you look for leaks? not to be sarcastic or anything, but water doesn't just disappear. The water is either leaking out or leaving as steam.bubbad said:no underground returns ,no leaks that i can find
no counter,but i catch drain in a one gal measuring can and watch how far the glass goes down0
thanks guys,for making me double check,i found a leaking spud nut,the installer checked everything upon install,in his defense these rads move a lot more than they did with the old boiler,you can hear them creaking and see new marks on floors lot more expansion than before,all my thanks to the guys that took time to respond0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
