Steam Pro in Northern NJ
georgehack
Member Posts: 2
Thanks to all the help on this forum we have our steam system in better working order then when we moved in, though its time to have a pro come in an finetune the system, rebalance and setup yearly maintaince.
Can anyone recommend a steam pro that services residental around the Hackensack/Paramus NJ area?!
I've tried the Find a Contractor section but haven't had much luck.
Thanks again
Thanks again
I will second JStar He should have come up on your find a contractor search. You might not have put in a large enough radius?0
There is also Gateway in the Orange area and Robert O'Connor in the Essex county area. There is also a gentlemen who posts under the name clammy who is in the Bergen County area. Don't know the names of their companies. There are actually quite a few good boiler men in New Jersey. It would be nice if more had ads here on Heating Help.0
Thanks for this very quick reponds! and yes i had only a radius of 10 miles, was trying to find someone very close to us. I'll check with Joe, and if 'clammy' has a licensed business then yes I looking for his adress too. Any more suggestions are welcome.
Many thanks.0 -
really good thinking about a lic. business…..no lic. no insurance…moomlighters, side workers, laid off union workers are a danger…If he pulls up in POV thats normally a bad sign...0
- 167 Indoor-Air Quality
