Possibilities in disabling intermittent water test on Hydrolevel LWCO
Double D
Double D Member Posts: 452
I know this question has been asked before but Is it possible to disable the intermittant water test on the Hydrolevel CG450 low water cutoff ?
  • Double D
    Hatterasguy, thank you for your quick response. When you say Safgard, you mean a LWCO that does not have the intermittent self test? My next move was to do just that once I confirm the intermittent test is causing the problem. When I have a little more time I will explain why. Thanks again.
