thermostat
Looking for a thermostat that can't be set below 50* anyone know of one? Thanks
  • This content has been removed.
  • DZoro
    DZoro Member Posts: 1,048
    You can set the high and low limits on most of the Braeburn stats.
    happydave
  • wogpa67
    wogpa67 Member Posts: 238
    You can do that on most digital stats.
    Jamie Hall Member Posts: 27,188
    And Honeywell makes one of the old style round ones like the T87, as well as a whole raft of digital styles.
  • JulianHBX
    JulianHBX Member Posts: 1
    HBX THM thermostats can go as low 32* for the set point.
  • icesailor
    icesailor Member Posts: 7,260
    Is there a particular reason you want one that won't go below 50 degrees?
