Smith Cast Iron Boiler Leaking - Expert Wanted
RichB
RichB Member Posts: 11
Hello All,
Looking for an expert with Smith Cast Iron Boilers, more specifically a Series 8 water with a manufacture date of '04, and in service date of winter '05/'06. Looking for someone to help me with the warrantee process, and its replacement. When facing the boiler it is leaking on the right side, above the fire box, between sections 2&3. I'm also toying with giving up on Smith and going to a Buderus or Viessman. I'm in the engineering / construction industry and as part of my responsibilities manage replacement of commercial/industrial HVAC systems, so I'm not your uneducated homeowner. Boiler is located in Putnam County, NY. (845) 216-5913
Thanks,
Rich
  • GW
    GW Member Posts: 5,133
    Rich, normally this is worked through the supply chain. Sometimes getting warranties processed is a pain, as you may already know. If you have had annual service your success rate increases quite dramatically. I don't have specific experience though with a leakin Smith series 8.
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • RichB
    Thanks Gary. It has been serviced annually, but by me. So I don't have invoices. I don't want Moe, Larry, or Curley touching my equipment!
  • Kakashi
    Kakashi Member Posts: 87
    edited February 2015
    What kind of L.W.C.O. do you you have?
    I only ask that since its been code in my area since 2000.
    Steamhead Member Posts: 18,179
    That boiler uses gaskets between the sections instead of push nipples. Maybe one of these has failed?
    Consulting
  • RichB
    LWCO is a MM GuardDog RB-122
  • RichB
    Yes, per discussions with Smith, can be gasket or crack in casting. I asked Smith what type of failure is more prevalent, they said they see more cracks than bad gaskets
  • Paul48
    Paul48 Member Posts: 4,469
    By the time you pay the labor to replace a section, you might as well replace the boiler. That goes for any boiler.
  • RichB
    From what Smith is telling me, they won't even do that, they only send the entire cube assembled
  • Abracadabra
    Uhm... I've replaced my fair share of Smith boilers, and in my humble opinion, I've seen more gasket failures than cracks. Once the gasket fails, the gasket seat and mating surfaces usually corrode to the point of no return. Trying to simply replace the leaking gaskets won't work at that point. Also, attempting to separate 15-20 year old sections can invite more leaks on sections that weren't leaking before. Like Paul48 said, might just be time to bite the bullet and throw in a new one. I wouldn't be happy with a 10 year life span on a boiler though.
  • Paul48
    So, you're essentially replacing the boiler. It's actually better that way.
  • SWEI
    SWEI Member Posts: 7,348
    Are they going to send an original Series 8 block or one of the "new" 8HE models?
  • RichB
    Smith's warrantee is based on 10 years, then they prorate it after that. I'm right at the 10th year. If I can get a new boiler through Smith under warrantee, I'll do that, but if I can't, I'm toying with going with another brand. And no, I'm not happy with a 10 year life at all.
  • Paul48
    So much for a lifetime warranty.
  • billtwocase
    billtwocase Member Posts: 2,384
    Possibly a cold start boiler? If they will get you a new block, go for it. You will have to pay labor, and any other parts/fittings used. You will only get the remainder of the original warranty after that, and I would have the section bolts checked periodically for tightness. You can't beat push nippled boilers
  • RichB
    SWEI - Not sure what block it will be, long way from that!
    Bill2 - Yes, its a cold start setup. Any idea on the torque spec of the section bolts?
  • kcopp
    kcopp Member Posts: 4,610
    Steam or Hot water?
  • RichB
    Hot water
  • SWEI
    They're totally different designs. I believe the 8HE is actually a repackaged Peerless.
  • kcopp
    The Smith 8 now is TOTALY different from the unit they had then. Now its a Red peerless wbv.
    I had great luck w/ the Series 8's I installed. It was great as a steamer. My supplyhouse dropped the line....much to my chagrin. They had great representation here in NH.
    I still think a 3 Pass boiler on oil is the best way to go.
  • RichB
    kcopp - so who's 3 pass do you like?
  • billtwocase
    NH, I would say the blue boiler would be his 3 pass choice?
  • AlCorelliNY
    AlCorelliNY Member Posts: 63
    I'm in Westchester. Where in Putnam are you?
    Al Corelli
  • RichB
    Mahopac / Carmel border, off Drewville Road
  • AlCorelliNY
    Give me a call Monday.
    914-804-2234
    Al Corelli
  • billtwocase
    I think the Smith sections may still be made at Peerless in Penn?
  • kcopp
    I do have a Buderus 115 in my own home... however the Biasi b10 , the Pure pro Trio, and Pensotti are fine boilers too.
