There is only two types of compressors
from the view point of the compressor motor,that is. Say what?
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    The ones that turn and the ones that don't?
  • bob_46
    bob_46 Member Posts: 813
    not sure of your question ? I would say positive displacement and centrifugal .
  • unclejohn
    unclejohn Member Posts: 1,833
    Then from the compressors point of view there's only two types of motors.
  • Techman
    Techman Member Posts: 2,143
    edited March 2015
    The two types of compressors is as follows from the view point of the comp motor.But first a little info, the comp motor produces heat, that heat has to be removed from the motor or else the motor overheats and whackado,another comp bites to bullet. So the 1st type of comp is the "Suction Cooled " comp where the heat from the motor is eliminated by the cool returning suction gasses passing over the windings of the motor.This happens in all AC systems and in most medium temp refrigeration systems.Now keep in mind that the lower the suction pressure the lower the density of the freon and that lower density freon carries less molecules of "comp motor cooling freon", so, the "magic line" of the 2nd type of comp is at 0* evap temp.That is freezer compressors and only the rarest of medium temp comps. The 2nd type of comp (motor)is the "air cooled" comp. This means that the cond fan motor HAS TO BE ON ALL THE TIME THE COMP IS RUNNING, for air impingement to be blowing on the comp body to cool off the comp motor.So ,no cond fan cycling control or motor master type of device is allowed. This is related to the "Killing A Compressor"thread.
  • Harvey Ramer
    There is one more. Daikin I believe, uses compressor discharge to cool the motor.
  • Techman
    Oh yeah, in AC any "semi hermetic" that has the suction service valve bolted to the side of the comp ,right by the comp head , is an air cooled comp.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Terry I guess I will take a stab at. RECIPROCATING, OR ROTARY.
  • ChrisJ
    ChrisJ Member Posts: 17,047
    edited March 2015
    I'm confused by the question?
    Even in the GE Monitor Top there's two different kinds.
    1927-1932 uses reciprocating
    1933-34 uses a weird oscillating rotary pump
    1935-1938 uses a scotch-yoke reciprocating type.
    Here is a video of the oscillating rotary being turned by hand. I've yet to see this design anywhere else.
    http://youtu.be/gn0u7dFBCTk
    Same pump running with the fan visible.
    http://youtu.be/bfkNLHy9nkw
    Besides that, you have scroll type, rotary vane and a few others, no?
    Or is that not the question? :)
    From the motor's view I'd say they are all slightly different. I can't see that oscillating rotary being the same as a reciprocating pump.
  • SWEI
    SWEI Member Posts: 7,348
    It's almost like a scroll compressor with only one turn.
    ChrisJ
  • Techman
    This thread was started because of another thread in which the freezer comp was being killed by the use of a cond fan cycling control. The motor in the freezer comp gets hot and is cooled off by the air from the cond fan motor hitting onto the comp body. During the fall,winter,spring on windy days the cond fan motor can be off for the entire comp on cycle. I see lots of freezers w/ cond fan cycling , or motor rpm controllers. That don't make it right. I make 'em right.
  • ChrisJ
    Shouldn't most if not all of the compressor's cooling come from cool vapor from the suction line?
    My neighbor's fridge is dying and he told me he has no complaints as he got his moneys worth because it's 15 years old. I told him to get back to me when it hits 80. :D
  • bob_46
    I think the main difference between your frig and your neighbors is. Yours new was $300 and a new full size Ford was $385 and your neighbors was $1000 to $1500 and a new full size Ford is
    $25000 plus . There was a lot more quality built into your GE .
  • ChrisJ
    True,
    But you would think over a period of 65 years some improvements could've been made in cost vs quality. The only thing that has improved is size, weight and the power factor of the compressor.
    So back on topic. Aren't most compressors cooled mainly by return vapor?
  • Don_197
    Don_197 Member Posts: 184
    Most are.............even the semi hermetics above. Open drive compressors are air-cooled. http://en.wikipedia.org/wiki/Vapor-compression_refrigeration
  • bob_46
    That's an awfully broad question. In general recip, rotary, scroll and centrifugal can be hermetic or semi hermetic in which case they are cooled by suction vapor they run from 1/4 to about 1500 tons. Recip , screw and centrifugal can also be open i.e. the motor or steam turbine is separate from the compressor and are not cooled by suction vapor . The biggest I have worked on is 7000 ton steam driven. I have never seen a compressor cooled by the condenser fan .
  • Techman
    All "suction cooled" compressors have the comp motor cooled off that way. The cool suction gas is passed over the motor windings, cooling the windings. This group includes all "regular" residential/commercial AC , some commercial AC has the cool suction gas go directly into the comp suction intake and NOT going over the comp windings, which means that the comp motor is an "air cooled" comp.Any/All comps operating at 0*f evap temp or lower require "air impingement" on the comp body to cool off the comp motor.
    pecmsg Member Posts: 6,740
    R-134A Liquid cooled windings
    400- Ton Cintrif
    Centrifugal
  • ChrisJ
    edited March 2015
    I wish I had a "condenser water supply" pipe in my basement....
    That's not sarcasm.
    That's not sarcasm.
    I wish i had trhe basement
    BTW
    2400 Volt on that motor
  • ChrisJ
    I don't see much need for 2400 volt in my house.
    440 3 phase would be handy though.
  • NYplumber
    NYplumber Member Posts: 503
    Good info Techman. Thanks for the post!
    :NYplumber:
